Hi bro na 15 plus use pannitu irukean bro.some cal atten pannum pothu illa cal pannum pothu beep sound varuthu bro cal pannathum ringer sound varama ah beep sound vanthutu tha ringing sound varuthu bro
Cal pannathumea beep sound tha 1st varuthu bro ithu ena issue bro.oru two weeks ah tha note panna bro.ena issue nu soluinga bro…
Airtel network use pannitu irukean bro
hello bro, iPhone model and current iOS version?
Yes bro 15 plus 17.5.1 version bro
ok bro. some settings change agirukumnga. once perform “settings - general - reset - reset all settings” then set proper ringtone bro. then check during incoming call if you are hearing same sound or not.
Bro call atten pannathum beep sound keakuthu bro.
Outgoing cal pannum pothu beep sound vanthutu aparam tha cal poguthu bro
ethukum once nearest apple service center la check pannidunga bro. device problem a irukathunga. mostly network service ethavathu active a irukalaam. so technician personal la once check pannidarathu better.
Ok bro thank you
Same scenario for me, I guess. It’s not an issue; it is to inform you that you have set the call volume to full. Same goes for headphones while set to full volume.
