Im using jio prepaid e sim and getting call failed pop up often while making calls how to fix this
hi bro, this could be temporary issue in your city or area. kindly report it to jio support. I experienced similar problem last month for one week time, they fixed it. now its working good. this should help.
Ok thank you bro
Hi bro spoke to Jio support the issue is from their side only as u said!
