My iPhone call drops every time , how to fix this issue , I
am using Jio , in my area the tower connection is good
Do you have 5G setting ON bro? Under mobile data options? Can you try changing it to LTE and check again?
Just now found that many other users using Airtel and Jio also facing same problem bro. it could be temporary network problem, normally gets fixed automatically. give some time. do restart your iPhone once just as a basic step.
Yes bro , I already tired that basic steps not working hope it’s fixed later
i’m facing this issue in vodafone too…mostly occurs when trying to call someone 2nd time…this msg displays twice and then the call would get connect in 3rd attempt.
my brother is using vodafone in coimbatore bro. whenever I call, it goes not reachable. even though he is near tidal park. it is good to check with vodafone customer care and get new SIM card for same number if necessary. sometime old sim card we use may cause such problems too. give it a try.
