iPhone Call failed Problem
Hi Robin,
Actually i tried all the steps which you mentioned in call failed solution video. But even though I’m facing same issue so kindly provide any other solution it would be helpful for all
hello bro, Did you try changing the SIM Card bro? is it physical or eSIM you have and which Network?
Hi Bro,
Last 3 months before only i changed my network from Jio to Airtel so my SIM card is very new only.
Actually I’m facing this issue after i change the network. I already raised network side issue concern
As said in our video this could be temporary issue in your city or area bro. let airtel work on this from their side, and in 3 to 4 days maximum you will see the difference. support ticket already created correct?
