Hi bro
I’m new to iPhone!
iPhone la ulla photos, videos iCloud la sync aagama iruka ena pananum ?
Kindly check with case from ringkee?
Is this case is good ?
If anyone using ringkee case, kindly provide your suggestion.
Waiting for your reply!
Hi bro
I’m new to iPhone!
hello bro, settings - icloud - photos sync feature off pannidalaamnga. once icloud pathi basics pathudunga,
you can search our channel or install our iRobinPro app from appstore to search in one word to find most solutiosn faster
Ringke has good user reviews so far. but the pricing seems to be higher for its overall product quality. do check ESR and Spigen Brands too. for the same pricing I would prefer Spigen brands bro. under 1000Rs budget means, Ringke, ESR Brand cases will be good idea.
Okay bro !
Thanks for your reply. I will check in your app and also that video too .
For case - I’ll check and update the same here bro .
Stay tuned
