iPhone condensation due to Low temperature due to AC
Iphone 13 screen becomes wet due to condensation,
I just put the phone in my table which is far away from AC but for these few days, the sceeen ,the camera array becomes wet, if it is normal condition or anything else?
that is so strange bro. was the AC too strong in the room? newly installed or serviced? I am using my iPhone since iPhone 7 in AC room. so far no such issue happened. may be try with 360 degree protection case temporarily to avoid such issue.
are you seeing water bubbles inside camera glass surface or display internally?
Yeah bro the indoor unit is newly installed
Night time i just picked up and took the phone and felt the moisture and condensation was occurred in Screen and Backcase (Nilkin) and in the Back Camera protection tempered glass too
No bro no waterbubbles inside camera array or Display by God’s Grace, i put extra good Spigen tempered glass for Back camera array
Its like mist or moisture forming due to condensation but i dunno what to do
Is that serious ?
But i dunno what to do
Infact i just cover with a good semi woollen cloth but although screen condensation happening, what can i do bro? Is that serious?
I hav put back camera tempered glass , thr it forms like a Fog (namma cold climate la Car windshield la form aagum la bro mist adhu maari form aaguthu)
understood bro. due to metal frame and new Ac unit may be the reason for such condensation. as long as you dont see internal water molecules formation, then not to worry bro.
it will automatically change.
Hi broo
i dont use magsafe ,so wired ah iphone ku best power bank edhu bro? 10000mah under RS,1.5k
unga suggestion sollunga bro ,which brand is safe to use(atleast with heat protection) (power bank usage only when travel)
URBN brand consider pannalaamnga. but 1500 budget la 10000 mAh irukunga. which has 1 usb c port only. for 2 usb c port 20000 mah only available.
so budget poruthu decide pannunga.
Hi Bro, am using Ip13 base variant and currently im on ios 17.7.2
Shall i update when its ios 18.3 ?
Yes bro. 18.3 is much stable than initial 18 release. you may wait for one more week and see user reviews and decide to update directly to 18.3 bro.
