iPhone Display Always Turned ON after Notification
My iPhone is always turned on when a notification comes. The display is not turning off after some seconds so my screen time and battery is affecting what to do bro
Hi bro, can you check within settings - display and brightness - auto lock is set to 30 seconds or 1 minute? is it set to Never?
Bro it is in 30 seconds bro
Do perform “settings - general - reset - reset all settings” once and then check bro.
Ok bro I will try and say
