iPhone HEIF, HEVC Not Opening on Android, How to Fix?
bro iphone la edukura videos ellam mov extension la save aguthu ippo nan android ku share panna video is not opening epdi extension ah change pandrathu can you tell please
Hi Bro, under settings - camera - formats - Most compatible nu set pannunga. that way we can play those files on android or windows systems too. output file will be .mp4. Otherwise using third party apps like Infuse Player or VLC player on android also helps.
HEVC or .MOV files can be played with third party video players.
irobinpro how r u , neenga enda format use panringa most compatible or high efficiency bro,
bro yan friend windows laptop use panran after updating ios 17 version windows system la iphone photos not working bro yapdi fix panalam
Hi bro, currently I am using Most Compatible bro. its easy to share and keep the content optimised without much reduce to quality. Rarely for portrait shots and high res video I change it to high efficiency. other times most compatible suitable fo rme bro.
Other platform OS compatibility issue illama iruka Most compatible set pannunga. that will be good.
