I have used iPhone 20 w adapter to charge my iPhone and I bought on July 2023 and now my battery percentage is 89 and when I was charge my phone it produce so many heat. Instead of using 20w adapter can I use MagSafe charger or 5w apple charger to charge my phone and use powerbank to charge iPhone is advisable are not. Kindly suggest me.
Hi bro, have you updated to latest iOS 17.4 version? 20W adapter is not a problem here. if its software issue, make sure to update to latest version. Then perform āsettings - general - reset - reset all settingsā once. and check how it works for next 3 to 4 days.
magsafe charger also produces some heating but its more like warm temperature.
5W is always good choice, but it charges the device very slow. if thats ok for you, and you have one, you may use it. otherwise continue with 20W and keeping optimised charging feature ON under battery settings helps to maintain it overall.
Yes you can use powerbank whenever necessary with original or mfi cable.
