Brother yaenoda mobile charging time 20 upto 75 percentage varaium over heat akuthu bro antha time la adapter also heat akuthu bro after 75 percentage come to normal both of them device and adapter
During fast charging heating is normal bro. Device will automatically cool down after reaching certain percentage. Dont worry about it.
Make sure to use original or mfi cable always.
Thankyou brother ![]()
