iPhone overnight battery drain is high
Yesterday night before I sleep i check my battery % it’s around near by 85% early morning it reduced upto 57% bro.
that is not normal bro. usually 10% or around is normal overnight. but again it depends on network conditions too. your iPhone model and current battery health percentage?
Bro now it’s okay… btw the battery health is 100% and i have reset all settings and now it’s going well
Good to know bro. continue using it and you will see difference based on usage in coming days.
