iPhone Ringtone Issues in Landscape mode
anna mobile holder la portrait orientation off pannittu landscape mode la holder la vacha vara incoming calls ring silent aagiruruthu just 1sec ring sound kettu apdye silent aagiruthu apdye holder la vaikkama just table la or chair apdy vacha sound varuthu portrait orientation on pannittu enga epdy vachaalum sound varuthu ithu ethavthu problem ah ? Illa ella mobile um ipdythaana intha holder than use panren in cause romba saachu vacha apdy irukkonu konjam konjma nera vachu paarththen appavum orientation off panna volume varamatenguthu enna panlam or normal thana?
Hi bro, focus mode ethavathu configure pannirukeengala? or ON la irukaanu once check pannunga. IOS related bug a irukavum chance iruku, but basic check pannitu decide pannalaamnga.
Anna sounds and haptics , focus, automation nu basic ellam chk panniten but no use
Perform settings - general - reset - reset all settings once bro. then check. if same issue iruntha then its iOS specific bug a irukalaamnga. settings change ethuvum reason a irukathu. so try pannitu paarunga.
