Hi bro, I’ve been using iPhone 16pm and I’m using the screen protector that you suggested on one of your videos, the thing is I feel the screen’s quality is not quite good and also there are lots of smudges in the screen, btw I’m using a privacy screen protector, is there any other brand like ESR or spigen or something that you would recommend with smudge free and hydrophobic? Also at time when I’m using my phone at outdoors I feel a sudden drop in the brightness, is there anything that we could do about this?
Hello bro, I have suggested two different brands. is it czartech or supcares brand screen protector? I often check with my friends circle whether the screen protector they are using is working good or not.
We can choose branded screen protectors like spigen or ESR too, no issues in that. but depending on environmental conditions, temperature changes we may notice air bubbles and issues after 8 to 10 months usage of certain screen protectors.
Reason I suggest it at less price is, in such cases we should be able to change it. like once a year we can change case or tempered glass.
if there is a moisture or oil from our skin touches the display frequently, we may notice such change in smudge level after few months usage bro.
That sudden brightness drop is not good. could be the screen protector not properly applied or software level issue. you can change the screen protector now and see if that helps or not.
ESR Screen Protector for iPhone 16 Pro Max:
Supcares Screen Protector:
Yes you can choose ESR, Spigen or Supcares brand tempered glasses if you havent tried one already. If you have experiencing applying it, you can do it yourself. else check with any mobile shops and they could help fixing it for you. that will help.
