Hi Bro
I have first gen IPhone SE. I am planning to replace battery now. How much will it cost and is it worth giving a try.
Hi Bro
hello bro, right now 1st gen SE battery replacement is not possible at apple service center. we have to do it at third party service center only. price may be under 4000. also if you notice overheating or battery issues, then we have to check with same service center in future.
Right now upgrading will be good choice bro. instead of changing the se 1st gen battery.
