iPhone Shortcuts can cause security problems?
Hi Robin Bro, Hope you are doing well.
Is there any harm in using iPhone shortcuts that we download from google or other links?
Recently I downloaded a shortcut called Instagram reels which I can use to download Instagram reels.
hello bro, I am good. thank you. how about you? shortcuts run with limited permission in our iPhone or iPad.
  1. avoid entering any username, passwords when you execute shortcuts.
  2. avoid downloading any third party profiles while using such third party shorctuts.
rest should be fine bro. we can use any simple shortcuts we download from internet.
Thanks for your quick response, I didn’t understand your 2nd point bro third party profiles mean
sometime, a shortcut or a website we visit may try to download 3rd party profile like this one bro,
We should not download and such profiles or VPN profiles as it could be security risk. other than that, no problem. we can use any shortcuts understanding the way it works.
Thanks for the explanation Bro, I can’t see any profiles like these.
If you don’t mine could you please tell me where I can check this?
It will pop up on the screen bro, in browser or as a separate prompt. Dont worry. If you dont see then not to worry.
Thanks, Bro, and also Kindly request you to upload how to create shortcuts by ourselves.
Done already bro :slight_smile: kindly check
Hi bro kindly share some useful shorcuts bro like yourube video download
Youtube shortcuts are not working for long term bro. thats why suggested safari method to download youtube, facebook, twitter and other videos easily
what about telegram bot?
Most of them are paid bro. I have used one, but after 10 downloads it started to ask for money. So I moved to this safari method.
ok bro thnkq
