Bro i didn’t subscribe any cloud service but my iphone storage shows 50gb in storage? What is this bug and how to resolve it bro?!
Hello bro, are you highlighting the iCloud Drive consumed 58GB storage space? do check Files App - iCloud Drive folder. If there are no files then check Files App - Recently Deleted Folder too and clear that space.
if those folders are cleared and give few hours time. if problem is not solved then we can to reach out to apple support.
This could be Server side issue. they will clear the iCloud Drive space for your apple id account from their end bro. that will fix it. You can install apple support app to reach them quickly.
