iPhone upgrade contacts sync issue
Dear irobinpro and team, Greetings. This is my first question in this forum. I tried searching for similar questions in the post but could not find any.
Pardon my ignorance. I am upgrading from iphone XR to iphone 16 pro. I had imported the same apple id from old device to the new one.
But i am seeing that all the contacts have not been imported from the old device. 1512 contacts in old device while 870 contacts in new device.
Both the devices are running on latest iOS. Kindly support. TIA :pray:
Hi sir, absolutely no problem. in old device which contact source is used for uploading? is it google contacts or iCloud contacts? you can check that on iPhone XR Phone App - Contacts - Lists (at the top left corner) to know which source synced to show contacts.
dear irobinpro, this is wat my screens look like. I have clicked the upload button here to reply with the image. Are you able to get the screenshot
Yes sir, I can see the screenshot clearly. on the right its iPhone XR which shows iCloud has 1512 contacts. Kindly give sometime. as contacts will be downloaded in the background, just charge your iPhone tonight to 80 or above and check tomorrow morning. You will mostly see all the contacts synced properly from iCloud storage.
