I’m using iphone XR from past 5 years last week I reset my phone and once I touch and move the centre button it’s sounds wired like vibration and I try to turn off the wifi button that time also the same vibration problem is there I try every settings can you help me
hi bro, could be some issue internally with the haptic feedback system. need to check with service center to understand the problem exactly. At apple service center they may charge for diagnostics. you may check with third party too. if they can do it without opening the unit it will be good.
