Hello bro, i am using iphone xr and thinking for an upgrade, but confused to choose btwn 14pro , 15 and 15 pro max. Can you suggest one?
all 3 models will let you feel good upgrade from XR model sis. you may check 15 and 15 pro at nearest apple showroom and that will help you decide whether to pick latest model or not. my suggestion is if you prefer under 1 lac budget then 15 model will be good choice. If you can find 14 Pro under 1 lac segment then yes its best buy in 2023.
Latest 15 pro models are quite expensive in India and if budeget isnt a problem you may pick 15 pro mainly for USB C port. other than that, 14 Pro is best choice.
Recently we see so many complaints arising on 15 pro models like hearing issue, back glass break in drop tests etc., waiting for some update from apple side is recommended or 14pro is the best option as you said? why am asking is bcz I am slightly leaning towards 15 pro for that 5x optical zoom, will it be a major difference btwn 14pro and 15pro max?
This year durability on 15 Pro and Pro Max back glass seems to be less compared to last year. that back glass can withstand minor drops and hits it seems. We have to use proper case in order to protect from damages or glass shattering when accidents happen.
People going for Pro model sometime goes with Applecare+ too. for 2 years complete protection and cheaper replacement of back, front and entire iPhone as well.
You may go with 15 pro max for its lesser weight, titanium frame and 5X Optical zoom features sis. Shouldnt be a problem. just handle it with care as we always do. and proper case with tempered glass will help.
Thanks a lot for your valuable suggestions bro🫡
Hello Bro, I am once again back with a similar question. I couldn’t make the purchase for some reason back then.
Now that i am actually planning to upgrade my device from iPhone XR, what would be the optimal choice?
Also is it ok to buy from Dubai? Will the features and updates be the same?
Yes sis. that would be good decision. Upgrading from XR to 14 or 15 models will be excellent. Yes you may buy from UAE region, shouldnt be an issue. Buy from trusted seller or shop always. for safety reasons.
