Hi Bro I’m currently using xr, and if I wanna upgrade which model can I upgrade to, or should I wait for the next year’s phone?
hello bro, from XR to 15 series or 16 series both are good upgrades to consider right now. as you are a long term user, going with usb c 15 or 16 model will be good upgrade. based on your budget decide bro.
iPhone 15 can be purchased around 55K price range with offers and cashback. do check with nearest apple showrooms and shops. that should help bro.
Thank you so much bro, can I upgrade to a pro model ? Will it be worth the upgrade or shall I stick with the non pro model?
Yes bro. pro models are always good to go with for 120Hz display and pro camera system. you can go with pro model if budget allows. my suggestion is to experience both pro and non pro model at nearest apple showroom once bro. you will feel the difference and that will help to decide much better.
