iPhone XS Max not charging sometimes
Hello @iRobinPro ji, my iPhone XS Max is not charging sometimes. When I restart the phone it started charging. it is running iOS 18 currently. Is there any known issue related to this? Do you suspect it’s a hardware issue? Please note, I recently replaced the battery from Apple service center.
hi bro, so far no such issues reported. it is recommended to check once at service center for any hardware repair possibility. as you have serviced at apple service center, its good to check with them for any repair or service possibilities bro.
Ok, will visit the Apple service centre soon. Thank you Ji!
Hello @iRobinPro ji, The charging problem is not seen after the hard/forced reboot. Looks like the problem is fixed. I will monitor it for some more days and keep you posted.
Sure bro.
