hi ,
while charging my iPhone 13 is getting warm , using apple charger and cable.
please assist.
hi ,
please assist.
during fast charging such heating is noticed bro. it automatically controls the charging speed after certain temperature reach, so dont worry you can continue charging.
iPhone 13, while using apps getting warm is it normal please advice
Depending on the apps we may notice such warm temperature bro. for example during video streaming if the app uses mobile data + gpu resources then temporary heating may be there. then it automatically cools down. if its too much heat then we need to do some troubleshooting steps.
Just restart iPhone once and continue using it. will be alright.
sure wll try
