Hi bro, Apple Magsafe Battery Pack Vagalama ? ; ₹12,100 Worth ahh ?
hello bro, Magsafe Battery Pack is an expensive accessory for sure. There are alternatives from Anker and Belkin today. So only if you prefer apple accessories and budget isnt a problem, then consider Apple magsafe battery pack.
Otherwise Alternatives at half the price is always good choice bro.
