Is Apple Watch battery change is possible ?
Sir iam trying to buy apple series 6 44mm LTE model from second hand , they say battery percentage is 84% , is their any chance so we can the Apple watch battery ? Is shows the service is 8000 is that right ?
Hi bro, at apple service center changing battery is not possible for apple watch. they replace entire apple watch if in future you take it back for battery not holding up. usually apple watch will still function normally even if it reaches below 80%. But buying something with good battery health around 90% atleast with good deal price is recommended.
Else consider waiting for some offers and go with new one, if you are concerned about the battery.
Ok bro thanks for your feed back
