Is iPhone SE Good as Secondary Mobile?
I wanted to buy second hand iphone as secondary iphone. I am interested in 4inch form factor and complete white back body like iphone se 2020 version . Which model would be better to buy and in what range ?
Yes bro. iPhone SE 2020 is good to consider as secondary device. if your usage is average like few calls and checking apps for couple of hours a day, then SE 2020 model with atleast 90% battery health will be good buy. as you set with the requirement of screen size for comfort and handling, SE should be good. iPhone 12 mini also good to consider but price wise it will be high.
SE 2016 model available for 9k . Fresh piece, is it worth taking ??
no bro. thats not good buy in 2023. consider atleast 2nd generation model.
