Iam using ipad 9th generation is it good for games like pubg and cod
When we play continuously will the battery or anything get affected??
no problem bro. both iPhone and iPad are excellent choice for gaming. many streamers and gamers prefer them too. battery is affected based on your usage. so if you have continuous usage, then battery will be consumed.
Dont worry about battery when you buy the device. use it to the fullest and get the best out of it. thats what important. the device should serve the purpose.
Thank you soo much broo for your information
