Is It Possible to enable Passcode before iPhone Shutdown?
Yaru venalum namma iPhone ah Switch off panna mudium Phone Lock la irunthalum
Power key plus volume up key press panna power off panna mudium power off panna
Find my IPhone disable agidum
Then IPhone security system romba poor thane robin bro previously na Samsung Galaxy A52 Use panne phone switch off pannanum endal kandipa phone password ketkum but iPhone la intha security illa so Apple ah vida android advance ah irukanga
I think Apple skip pannitu android ku change agurathu better nu ninaikure
Ungalaoda suggestion sollunga bro
I was planning to do a youtube short about it :slight_smile:
Good question by the way.
Just because of one feature missing while comparing to android, we cannot say iPhone is poor security bro.
iPhone 12 and above models allows us to Track iPhone with Find my feature, even after switching it off. It uses low power mode to let the owner of the device find exact location for long time. If the phone is ON then battery drain happens faster. But when its OFF and still find my able to locate it, we can search and find location of iPhone for longer duration. Thats a big advantage.
Antha reason naala iPhone switch off pannumbothu passcode enable agura feature kondu varama irunthirukalaamnga. sila problems ku apple side la pannura solution and implementation different irukumnga.
Android OS and daily usage ku safe a irukuna android switch agurathu better. But android phone off pannurathuku passcode ketaalum, with some tools or for some reason, thieves successful la off pannitaanga na, track pannurathu possible illainga. iPhone can still be tracked :slight_smile: I hope it answers.
Thanks bro Robin bro
Itha pathi oru detail video potta romba useful ah irukum because na IOS ku puthusu so innum enaku Apple pathi theriyathu so unga videos itha pathi detail ah potta na learn panna easy ah irukum
Kandippaanga bro. Sila highlights mention pannurenga. Already find my video potrukean also some safety tips to follow, like these.
Switch Off pannalum iPhone ah locate pannurathu epdi? Please make one video
And thanks for your quick response
Keep it up robin bro
