Is it possible to see iPad Battery Health?
Can we see the ipad battery health bro
We have to use shortcuts like this one to check battery health or cycle count bro.
https://www.icloud.com/shortcuts/b68145a9f2174f7686727234ad458094
Turn ON Settings - Privacy and Security - Analytics and Improvements - Analytics Data. Then wait for 2 days and run this shortcut bro.
Hello bro, I’m using iPad Pro 11 3rd gen, it’s getting heat even for normal usage. I checked battery health it shows 166 count and 86% health, is it possible to change iPad battery , what will be the price?
Hi bro, heating could be temporary issue due to some apps and services. is the iPadOS updated to latest version? any specific app you are using while noticing such heating?
iPad battery replacement is still not possible at apple service center. I will check once again and update you. for now, the battery health is good and it will come for 10+ months usage to reach 80% level. not to worry, iPads can work good even after going below 80% battery health level.
I’m just using flipkart, amazon, app, google chrome app bro. Suddenly it’s getting heat,i don’t know may be its because of weather ? yes I updated it 18.5 OS already,
temporarily air circulation could be the reason bro. observe for a week atleast and see if any improvement is there. else we can try troubleshooting steps like all settings reset. but its too soon to try as the issue just occured.
Hello bro, if I buy MacBook in Malaysia or Singapore, do I need to pay custom tax in India?
No bro. just for personal use, customs wont ask for any tax when you come to india.
