Is it Worth buying US iPhones?
Is it worth buying US region iPhone with dual sim (No career locked) in local 3rd party vendors? Is there any issue in warranty claim or hardware replacement?
Yes bro. If your network supports eSIM, then getting iPhone eSIM only options from USA can be used in india. network bands also supported here. so far no issues with warranty claim. it is possible. replacement happens only with indian unit if there is any need under warranty or applecare+.
Thanks bro! Much appreciated for the quick response!
