Is macOS Hard to use? 15 inch macbook air for Trading and movies
hi robin pro how r u, bro na macbook vangalam oru idea iruku im windows user mac os romba kastama irukuma use pana or its user friendly , na macbook pro 14 inch or macbook air 15inch vangalaam edu vanagalam yan usage online trading and watching movies in 4k and in my shop 6 hrs use panra madri irukum bro and iphone back up and restore panrathuku use panuvan bro yandu choose panalam AIR 15 or macbook pro 14 inch base which one is best kindly give me good solution choose laptop
hello bro, I am good thank you. Hoping you too. 15 inch macbook air is best for its bigger display bro. but if you need ProMotion and budget isnt problem and need best hardware specs, then 14" macbook pro is definitely best buy bro.
My suggestion is to experience both models at showroom. spend 20 to 30 minutes with the computers. see which one you find comfortable to use. that is very important.
Mac basics video namma channel la irukunga. that will help for starting. 512GB SSD minimum porathu better bro. as you store backup of iPhone.
Trading ku neenga use pannura apps mac ku available irukaanu paarunga. thats very important before choosing mac computer. otherwise Windows laptop thaan besta irukumnga. neenga use pannura trading softwares Windows la mattum thaan available iruku appadina.
