Issue after 26.2 update in iPhone 13
Hi,
I have updated to 26.2 when Apple released update. Since then I am facing the two issues one is Touch issue and the other is can’t change my Apple account photo and also in the Gmail app if I delete the email from inbox alert message was displayed but email shows still in the inbox. Attached images for your reference.
Please note that already discussed with the Apple team and I have not faced any kinds of such issues until I update to 26.2.
hi bro, touch issue in home screen and other apps? or particular app?
tried reinstalling gmail app to see if the deleted mail reappearing issue fixed or not?
All apps and gmail tried multiple times.
this needs to be checked with apple service center once bro. for any hardware defect. if its software issue then performing iOS Restore will fix it. after taking backup of the device using computer.
Else diagnostics run at apple service center will help us identify the root cause.
All possible options are completed already still the issue persist.
So far no similar issues reported from fellow 13 users bro. so its possible issue is your device specific. if iOS restore didnt fix then its clearly display hardware specific issue. kindly check apple service center for proper diagnostics and replacement of display may be needed if there is an hardware issue.
You can decide based on cost of display or exchange offers to switch to new model according to your budget bro.
Apple technicians also confirmed it’s not a big issue or any hardware issue. By the way, I can’t change the Apple account photo too tried all possible settings but not successful
Checked with a friend using iPhone 13 pro and he is not experiencing same problems bro. if the issue not fixed with all settings reset then iOS Restore will fix them. Strange you are experiencing the issue even after iOS Restore done. updated to iOS 26.3 bro?
I addressed it earlier to the Apple team, and they also confirmed that it will be fixed in the next update. Already updated to 26.3, the issue got fixed.
