Bro In Contacts App In My Card Section Whenever I Add My Contact Details It Shows For Few Seconds And Disappear Immediately…I Tried It a Couple Of Time But It Hasn’t Fixed Yet…Even Updated To Latest Software Version…Pls Suggest Me A Fix Bro…
hi bro, do you have iCloud Contacts ON for contacts? under settings - your profile - icloud section and check. also inside phone app - contacts - lists at the top left corner. make sure icloud contacts toggle ON. let me know if above settings are correct bro.
Bro Everything Is Turned On And I Tried Again But Still It isn’t Showing
some temporary issue bro. have you updated to iOS 16.4.1?
Yes Bro It Doesn’t Work
Try configuring Health app details bro. open health app fill out date of birth and other details. it will also update my cards section.
