Recently I have bought Apple TV 4K. All features are working fine, but still AirPlay, I could not able to use it. I could not able to share any of the photos in my gallery via AirPlay to my Apple TV 4K while searching in AirPlay in my iPhone 15, it shows no nearby device found for this. I have contacted Apple support. They are telling that AirPlay should be supported by your TV then only we can use it.is it true? Could you please share me your suggestions or comments?
hi bro, if we have apple tv connected and iphone connected to same wifi network, then it should work normally. when you go to control center and tap on screen mirroring option it automatically shows the apple tv available in the same network.
Its possible some settings issue with apple tv or wifi network that is preventing the service working normally. can you check with apple service center in person once? take the apple tv with you. if iPhone or apple tv is under service warranty, they will assist you on this better.
As per your previous message, I had done the screen mirroring. It is getting positive in the Apple TV. I can able to share my screen, but even though AirPlay, I could not able to do it similar to this, any suggestions can able to give me for AirPlay.
the screen mirroring by default uses airplay feature bro. thats how screen mirroring works with iPhone, iPad, Mac and Apple TV or any TV with airplay enabled.
