Bro, Jio has upgraded the physical SIM to eSIM, and the transfer process is super easy now—just through settings. No more complex SMS or IVR process, as simple as in other developed nations.
You can do it like this:
- Go to Settings.
- Select Mobile Services.
- Tap on Convert to eSIM (above the Add eSIM option).
- Activate the eSIM.
It’s official info from Jio. Check it out here: http://www.jio.com/r/zcyKjWSHi .
Bro, you can make a dedicated video about this so that more people can opt for it (because it’s no longer techy and complicated).
