Keyboard sleeves for Macbook Necessary?
Hi bro, I am Vignesh here so recently bought a MacBook Pro 13 inch M2 So as I have been seen your video regarding the screen protection, I have placed the screen protector successfully, but I have another doubt regarding the keyboard sleeves. Is it compulsory to have keyboard sleeves to use, or else I could create any defects on keyboard like removal of paint of keyboard letters from my MacBook Pro…. So kindly can you suggest me that I can have the key both sleep compulsory or it is not necessary.
hello bro, as I mentioned in our video, keyboard sleeve is not necessary when you applied screen protector. keyboard sleeves protect from any liquid spills mainly. it does help paint chipping problem. but so far mac keyboards I have seen even after 5+ years didnt peel off or keys paint removal. so maintain it well and it shouldnt get such paint problem.
wearing both sometimes affect the sleep mode feature to work properly from what I have seen. So suggested in the video to wear any one based on the importance.
Screen protector is must I feel.
Okay bro, I understand your suggestion and thank you so much for your kind reply bro so that I will only have the screen protector and I am not willing to go for keyboard sleeves. Thanks once again bro.
Welcome bro. Make sure to not bring any liquid near your macbook when its opened. Tea, Coffee, Juice or Water. when you setup and use it at desk or using it at lap. be bit careful. that will help.
Sure bro i will follow
Thank you
