Lightning to 3.5 mm converter suggestion
Suggest a third party lighting to 3.5 mm converter.if mic doesn’t work in it.its okay i only want to listen with best quality
hi bro, as I checked on amazon most of them have poor lifetime. non mfi certified lightning to 3.5mm converters cannot be assured when it will stop working due to power differences. Apple original lightning to 3.5mm adapter costs around 900 but finding stocks is bit tough now. that is the only way bro to use with wired 3.5mm headphones bro.
You may check with apple showrooms or service centers for adapter availability too.
