Hi bro ,
Hope you are doing well and good ![]()
Kindly suggest lightning to 3.5mm jack converter buying link for iPhone 13 .
Hi bro ,
Good bro. thank you. hoping you too. when it comes to lightning accessories using original is always good. other products could cause product life issues.
Okay bro
Thanks for your reply
Can I use IEM earphone with my iPhone 13 bro ?
Bro
I checked in Apple website and it is showing not available bro !
What can I do bro . I need this for my iPhone 13
Currently its out of stock bro. we have to wait for some more time. also check with any apple showroom nearby they may have stock. just call and check with them.
Yes we can use it with IEM headphones too.
