Limited Warranty and Applecare plus, Whats the difference?
What does it means bro ? Two dates are mentioned there… ?
What is additional coverage date bro ? Is that can i able to buy care+ before that date ?
Limited Warranty comes with our purchase bro. normally 1 year manufacturer defect will be covered.
Applecare+ covers manufacturer warranty and any user caused damages. Applecare+ explained in this episode for reference.
bro im asking about the two different dates…especially the date mentioned under apple care+
Applecare plus applying time limit bro. Within that period you can buy applecare plus. Normally its 90 days, but the date you are seeing may be an error. You can call apple customer toll free and confirm the same. Whether its possible to apply applecare plus before the mentioned date.
