Hi bro sorry to disturb, I find ios 18 security problem , lockscreen I replace torch light icon change flight mode icon , after locked phone I hide my Face ID with my finger also , flight mode enable and disable panna mudithu, ur developer beta user u can tag to apple can possible to fix issue.
no problem bro. possibly a bug. but lock screen controls allows us to access the feature that we setup. but I will send a feedback using assistant app. lets see if they check and fix it if required.
Ok thanks bro
