Bro my m1 mac battery count is 43 will battery affects if the count exceeds at some point or not
Hi bro, as we use the device it will keep on increasing. thats normal. dont worry. Macbook batteries normally lasts for 4 to 5 years. then we change battery at apple service center to continue using it.
im using macbook air mid 2017 battery cycle count went above 1200 now its showing serivce recommend ? its worthy to change the battery ? and how about the cost?
If you are seeing fast battery drain and any problem with apps functioning normally, then you may change it now bro. else give some more months and change it according to your usage.
ok bro . cost idea erukah ?
For macs, battery replacement could cost around 15 to 17K price range bro. You can check model wise cost by visiting or calling apple service center in your city.
