Hey I got offer for M1 MacBook Pro 16” and M2 MacBook Pro 14” at same price point. So give me suggestions to chose the best processor. I know both are performing well. But still in confusion to choosing the processors. Help me out ![]()
Hi bro, Both models are targetted to different type of audience. 16 inch macbook pro is always superior. If you can find one with bigger storage like 1TB SSD then 16 inch macbook makes lot of sense for your data science usage bro.
14 inch macbook pro, only if you want a compact and easy to carry macbook pro model. 16 inch is bit heavy as mentioned by most reviewers. so decide accordingly bro.
