irobinpro my sister working in singapore airtravels for booking airticket ,online ott 4k movies, ms office, iphone back up and restore ios process and total working time 8hrs per day macbook air15 m2 8gb 512gb enough for 6 to 7 years usage varuma ok va she want to buy i aslo send our link ask.irobinpro website to follow you kindly reply me bro
hello bro, 15 inch macbook air with the said spec is good for mentioned usage. For long term usage and better multi tasking after few years 16GB RAM also helps to run apps smoother.
You can buy it directly from apple website bro. currently student discounts are going on. So if you there are any family members studying then you can use their student id card to get the discounts following the steps in the video.
Or you can go with GST Input option if you want to bill it under business.
