M4 air 15” for AutoCAD usage?
I am Civil Engineer. I am using AutoCAD on daily basis. I am planning to buy MacBook M4 air 15” 16 gb and 512 gb SSD model. Is it okay to buy this or shall I go for Pro variant?
Hi bro, Macbook Air M4 can handle autocad for most works. Only thing we go with pro model is to get that extra power to handle projects that require more resources. so if budget allows going with Pro model is always good idea.
But if your usage will be moderate and projects you use normally average power, then regular m4 model is perfect choice. It does fit for most users use case.
Any fellow audocad users using recent last year or couple years older macbook in your surrounding means, checking with them which processor model they are using also helps with the decision.
If they are using M2 or M3 chip macbook model, then going with M4 model will be best too. Else Pro model will be wise choice.
