Mac mini m2 16GB Ram vs 512GB SSD Difference
Hi @iRobinPro Hope you’re doing good? May I know difference between Mac mini m2 16GB RAM vs Mac mini m2 512GB SSD variant difference ?
Which one should be best to choose ?
Higher RAM is good when we do more multi tasking, photo editing works bro. Virtualisation especially. More storage is suitable when we want to store more data locally in our primary SSD. and dont want to use external drives.
Also higher the SSD capacity, we get better read and write speeds. 512GB and 1TB Storage are always good to consider for long term usage and people who need it for video editing.
Here you have to choose based on what your usage will be.
If you need more storage then 512GB it is. If you want more multi tasking to do then 16GB RAM is good idea.
Budget and Usage, choose the mac mini based on these two key points bro.
