Macbook Air M1 Battery Health 3% Reduce
Hi is the 9 months → 3% battery health drop is also applicable for mac i have bought the machine on oct 2022 and now july 2022 so almost 9 months before 1 week i have checked it was 98% and now it is 97% after one week and the Charge Cycle is :103 is this normal?
IF not are there any charging practice to be followed like and one thing i charge the macbook air whenever i need the juice to work for a day and also when i play games via parsec should i need to wait till 20 % for the usage of battery everytime or is it not necessary?
hello bro, for 9 months usage its normal. dont worry. for all lithium batteries the same charging practice helps to maintain it. not letting the battery drain frequently. with mac we can also use it with power source connected whenever needed. so far you were doing it correctly. continue the same bro. from my observation it took 4 to 4.5 years for mac battery to show the battery change notification.
