Hi bro, i had bought macbook air m2 8/512 model i am using right now, i am facing some issues related to my work i want to use 50+ gmail accounts in macbook air, now i am using gmail web for gmail,in that after sign in 10 gmail accounts it shows you have reached maximum number of accounts for sign in , but i want to use multiple number of gmail accounts maximum of 50+ , can you suggest any free gmail apps to use this kind of features in macbook air, please do consider and reply me, thank you
Hello bro, that is high number of accounts usage. I havent personally tried 10 or more on my mac mail app or third party app like Spark mail app by readdle on my mac. You can check with Thunderbird mail client, Mail+ for Gmail.
None of the developer mentioned any account limitation. So give this app a try and see if you are able to go above 10+
Also as per google policies, Managing multiple Gmail accounts, especially in large numbers, may trigger Google’s security mechanisms.
Thank you bro, i will try that one
