Macbook Air M3 or Macbook Pro M3 Pro? Which is Best Buy?
Hi bro, I have a confusion whether I need to go for Macook Air M3 with 16 GB RAM and 512 SSD or MacBook Pro M3 Pro with 18 GB and 512 SSD. Also, can I buy it now or I can wait till October release?
Usage: I am an Apple application developer and have company laptop already(MacBook pro). I will be using this personal laptop to prepare for interview and to work on some sample projects
hello bro, for app development macbook air m3 processor is a basic setup. but if your project has more graphic content or requires more resources, then its must to consider macbook pro model for long run. If budget allows go with Macbook Pro M3 Pro processor bro. it normally gets higher storage and RAM memory.
During offer period or with apple back to school offers at apple india website, if you take, the discount amount can be used for buying applecare+ to protect your macbook for 3 full years.
So if you can wait and not urgent, then consider during offers time bro.
