Macbook air or macbook pro for adobe photoshop
I am planning to switch mac os from
Windows. Since i travel to my native and stay there , imac can not be the final option to buy which i should buy.
So am planning to get one macbook air and then later in cooming months or in one yr will save and get imac.
Will that macbook air or base version of macbook pro be sufficient for using adobe photoshop and photo files of minimum 100gb on total?
Macbook Air M2 processor is very well capable of handling photoshop and video editing as well bro. consider 512GB if budget allows. Just to avoid any storage issues in future and to get better Read and Write Speed performnace for long term. Otherwise you may consider 256GB Storage model. it will do the job very well.
