Hi , bro mac m2 pro 13 inch 8gb ram 256gbinternal is that okay for college students. for coding and other developing purposes.And did dubai version will cause any disadvantage bro.
yes bro. It is very well suitable for students who wants to learn coding and use it. mostly we use web based softwares these days. like web apps and engines. there is no drawback with dubai version. if you want to, you may also activate applecare+ from dubai itself with the purchase.
Bro that the retail shop located in dubai and sealed piece. with one year international warranty .Is that trustable.
I personally dont have any experience with dubai shops bro. you are there in dubai right now or family or friends buying it for you? visiting the store in person and checking everything is good idea while making the purchase.
Bro by using windows as dual in mac would crack version software is useable.
I think you are asking about parallels desktop software to install windows inside mac bro. so far no cracks available to do that in m1 or m2 machines.
But while using windows as parallel desktop also crack is un useable yeah.
I havent tried the crack version personally bro. but if its available for correct windows version, then it will work.
