Macbook Brightness changing while charging and removing charger
hi how are you , as a windows madri ya mac book pro 14 charge podum podu brightness 80% when remove it from charger 50% mardu idu default a bro
nama macbook batteryla use pannalum performance marathu youtube vedio parthan charger podum podu yapdi use panraoma ada dana battery la laptop use panalum performance irukuma?
I am good bro, thank you. hoping you too. yes bro. its default power saving feature. we have to manually increase brightness if we need higher brightness even with battery usage. power plug irukumbothu video editing, rendering, photo editing and rendering mathiri tasks la thaan difference irukumnga. normal browser, video watching ku ellam difference irukaathunga bro. you can use it the way you want.
